Iraqvet05
Mar 17, 2019Explorer
I know GM had issues with stepper motors in their dash clusters that cause the gauges to stick or not read correctly. The odometer issue is most likely a bad solder joint. You can source a cluster from a salvage yard but may run into the same issue...it's a gamble with used electronics. There are many companies that do repair/return of your cluster and offer instructions on how to remove your cluster. Those cluster services are much cheaper than a trip to a dealer.
44,071 PostsLatest Activity: Aug 30, 2026
