Big_Love's avatar
Big_Love
Integrated brake controllers
Have heard different perspectives as to whether a TV with IBC allows TT electric brakes to lock up when adjusting the voltage to the electric brakes. Some say an IBC is designed to not allow the brakes to lock up even at the highest voltage setting, others say that if you cannot lock up the brakes, you need a brake adjustment. Maybe this is different for different makes of TTs?
  • My 2011 F150 IBC will lock up the brakes at 8.5/10, but only after I adjusted the brakes. As the trailer came from the dealer, the brakes were too loose.
    The IBC is way better than my previous Prodigy as it self-adjusts the brake voltage according to speed.
  • sourdough2224 wrote:
    My new 2014 Ram 2500 w/IBC will almost lock them up but not quite.
    No disrespect intended, just curious. How can you tell that they are "almost locked up, but not quite"? thanks, david
  • No brake controller knows when the trailer brakes are locked up. All they do it output a variable voltage to the trailer brakes. The amount it takes to lock up trailer wheels varies by tire friction, magnet strength, etc.
    On another thread here it was pointed out that the DirectLink (?) brake controller with their special ABS trailer module that requires sensors on the wheels (just like with cars) and disk brakes, can do just that.
    Sort of blew me away. And haven't heard of any trailer actually using it. Probably very pricey too.
    Correct the controllers are about $1800 and you still have to convert to hydraulic brakes.
