- Turtle_n_PeepsExplorer
USAFBILL wrote:
If you wear hearing aids you can get a unit that hangs around her neck and then you can stream her audio right into your hearing aids, the same way you can stream the TV audio into your hearing aids so as not having to blast everyone else in the room. Works great
^^^^^ This. - USAFBILLExplorerIf you wear hearing aids you can get a unit that hangs around her neck and then you can stream her audio right into your hearing aids, the same way you can stream the TV audio into your hearing aids so as not having to blast everyone else in the room. Works great
- charlie_good_tiExplorerIt will be for use in class a primally.I have looked at those on Amazon an i might stop at near buy Wallmart.There probably in sportings area.
- DutchmenSportExplorerOf course, you could always get one of these to use insider your camper too. :B
Staples.com - charlie_good_tiExplorerWould reccomend any of the ones on Amazon? There is a variety offfered.
- DutchmenSportExplorer2-way radios (or) walkie talkies would be the easiest. Get a set that has a mile or two range that boaters use. That way, you can use them for more than just the distance of a motor home. Would work great in grocery stores, or if one goes in the store and the other does not, or traveling in 2 vehicles even. They make some pretty nice ones (that are NOT for kids, but very much the grown-up adult version) that work very well.
Cabela's, Gander Mountain, Dicks Sporting Good, will have some nice ones. You also might check a boating parts store. Wall Mart has them too, a bit cheaper, but more for kids, and so does Best Buy (a little pricier - adults and kid versions). - charlie_good_tiExplorerWalkie talkies such as on Amazon?Do they also serve as a cb radio for very occasional use?
- agesilausExplorer IIIWalkie Talkies? Some cell phones can simulate that. Or a wireless intercom.
44,055 PostsLatest Activity: Dec 23, 2025
