bondebond
Jul 14, 2014Explorer
There's a very good chance that your PUP is pre-wired for AC. One quick check would be to look into the power distribution center/power converter where the 12v fuses and 120v breakers are located. Hopefully, there is a 120v circuit break that is A) labeled "A/C" or "Air Conditioner" and B) is 20 amps.
If those are true, you're in luck and just have to find where the outlet is hiding. It will look similar to this:
Notice the T-shaped slot on the left. This indicates that it can handle 15 amps (typical household outlet style) or 20 amps, needed for the A/C.
Look for this outlet inside cabinets if it is not visible on the front of the furniture.
If none of the above is true, then you're in for a little more fun. There are options, but I would suggest taking a picture of the power center first and posting it here if you are unsure.
