CA_Traveler
Aug 03, 2014Explorer III
modern family wrote:Larger ACs can draw 15A, so the answer depends upon the AC size.
Another question...
If you are on a 30 amp connection (as many state parks are) can you run both a/c's?
The TT we are looking at has 1 for the master bedroom and the other takes care of everything else. If I couldn't use both at the same time, that would create problem. Since most our camping is here -in fl / Ga.,..
Either us or the kids would not be happy...
Two large ACs - no
Two smaller ACs - yes but little else
Even two smaller ACs can exceed the recommended quide of a maximum of 80% or 24A of continuous draw. Many posts on these boards about overheated plugs and excessive draw is one reason.
