westend
Aug 10, 2014Explorer
DarrellQ2001 wrote:OK, let me rephrase since you didn't understand me: Will someone please explain to me how a 1/2 ton truck connected to a trailer weighing 8000 lbs.......westend wrote:
Will someone please explain to me how a 1/2 ton truck with 8000 lbs on the ball is "no problem", "just fine","like it isn't even back there", etc.? I've done a bit of towing and if you are not sensing that there is 8K on a trailer in back of you, the rig is either coasting or parked. Is this just internet hyperbole?
Who ever said there was 8000 lbs on the ball? I said the gross weight of the trailer is 8000 lbs. If you have ever done "a bit of towing" you would know there is such thing as "tongue weight" and weight distribution hitches. My 8000 lb TT puts no more than 600 lbs on the ball when the weight distro system is adjusted properly. And, no, I can hardly tell it is back there.
BTW, I know all about tongue weight and WDH and this has to do with the "awareness" of 3-4 tons being pulled. I'd just like to know if some folks can pull that much weight and 30' in length and drive like "there is nothing back there". I don't get it.
