mlts22
Apr 15, 2014Explorer II
I am almost certain that you have a single stage, "battery boiler", converter. I assume the rig is over five years old, which almost makes it certain that a single state is present.
I'd put it a priority to double-check this, and replace the converter with a multi-stage charger. This way, you won't be tossing batteries every season. Plus, if you don't mind ponying up a bit more, you can get a converter/inverter so you can use low-wattage items without needing to fire up a generator.
