BurbMan
Apr 16, 2014Explorer III
realter wrote:
I just looked and it is a WFCO, model WF8945AN-P.
Easy to replace with the PD-4645. Take off the front panel of the breaker box and there are two screws holding the converter in. Slide it out, disconnect 2 wires, then slide the new Progressive Dynamics Intellipower in its place and re-connect. Easy job. You don't have to remove the whole power panel or fuse box to change it out, the converter is just one component that slides out of the chassis. The PD-4645 was made a direct swap-in replacement to Magnetek, WFCO and other cheap OEM equipment, and comes with step-by-step instructions. Or, take it to the dealer and have them replace it with the same junk.
