Boatycall
Apr 17, 2014Explorer
realter wrote:
I've had numerous battery problems in my Northstar Laredo. 3 batteries in less than 5 years. Now the charger (converter) doesn't seem to be working. If I never boondock, always staying someplace with electricity, is it necessary to have a battery? The batteries are inside, so have to use the high priced lifeline type battery. Thanks for any help.
So, you don't have listed what kind of TC you have. But suffice to say, you have to have a 12v converter. All the lights, fridge, water pump and furnace run directly from 12v. Virtually nothing runs EXCLUSIVELY off 110v except the AC. Even the fridge set to 110v mode needs 12v to run the brain.
If you have electric jacks, you need at least one battery. If you try to run the jacks down, all 4 at once will burn out the converter. Most jacks draw between 20-30 amps each, and the average TC converter is around 45-ish amps. You could get away with one jack at a time, but what a PITA.
