mfoster711
Dec 02, 2015Explorer II
Thanks again for the replies. Since the responses still seemed varied, I decided to email Equalizer and ask their opinion.
Here is my email:
And their response
Here is my email:
I currently have an equalizer hitch and my friend is considering a purchase. Both of our trucks and campers are almost the exact same size and we both have the same questions regarding exactly which size hitch to get. We used the form on your website and it typically recommends the 10k hitch but depending on how much tongue weight or cargo weight we estimate then it sometimes starts to recommend the 12k hitch. When I bought my hitch I just went with the idea that it is better to get the larger hitch and not worry about it so I bought a 12k hitch. My friend is having doubts if this is the best logic to use and if he should get the 10k to make sure it properly fits his camper.
I started an RV.net forum topic on this subject to get opinions and the answers I am getting inconsistent.
In my opinion, how the hitch is set up is what determines the amount of weight being transferred from the trailer to the tow vehicle and you could buy the 14k hitch to tow a pop-up and it would be fine as long as it is setup properly. Others seem to them that this would cause a horrible ride or possibly cause damage to the trailer because too much weight is being distributed.
What is Equalizer's professional opinion on this?
And their response
I’m glad you contacted us as there is a lot of confusion and misinformation about this topic! First let me go ahead and dispel the biggest myth about getting a larger size hitch: a bigger sized hitch will NOT damage or bend your trailer tongue. I’m not sure how this rumor was started, but these frames are constructed to carry these humongous trailers and it will take much more than a hundred pound hitch to damage one. Especially since the Equalizer attaches to brackets that are attached to the frame and not the frame itself. So that is not an issue at all.:
As far as getting a bigger hitch, if there is any possibility of going over the GVWR or tongue weight ratings of a certain hitch, I would get the next size up. It is much better to have a bigger hitch than be caught down the line towing more than the hitch can handle. The only negative report I’ve heard about going bigger is a stiffer ride, and even this is when the “proper sized” hitch is a 6K and they go with the 14K. That being said, all Equalizers will be a bit stiff when they are new. This is due to the new steel-on-steel friction surfaces and the sockets being torqued a bit higher than usual. However, as you start to tow with the hitch will begin to wear together and break in and any stiffness will vanish after a couple of trips.
Anyway, long story short, you and your friend should have no issue going with the 12K as long as it is set up correctly. I would try to have your tongue weight ~10% of the trailer weight for the best ride, but even that can be compensated for with hitch adjustments. I hope this helps shed some light on the situation, but feel free to ask any questions you might still have.
44,066 PostsLatest Activity: Mar 14, 2015
