mfoster711
Dec 06, 2015Explorer II
Huntindog wrote:
I have owned both. (for a short while both at the same time) The 12K bars will NOT fit into the 14K head, and the 14K bars will NOT fit into the 12K head.
The 1/2 round slots at the end of the 14K bars are offset. On the 12K bars they are centered.
On the 12K bars you can flip them over and insert them into the same "reciever" since it's slot is centered. If you flip over a 14K bar, it will not fit in the same 'reciever". You would need to swap sides with it.
I think that customer service strikes again.
You are half right and half wrong. If you read the current installation instructions, it says:
Insert spring arms into the sockets in the hitch head. Arms for the 12K and 14K models are side specific. They are notched slightly off-center, and should be inserted into the socket with the notch on the inside, and with the label facing outward
The 14k and 12k are both notched (offset) but the smaller models are centered. So, it is very possible Deep Trax and the customer service rep are correct.
Maybe something has changed since you owned them?
44,066 PostsLatest Activity: Jul 25, 2018
