bobndot
Sep 26, 2015Explorer III
westend wrote:bobndot wrote:Some LED replacement bulbs have a switching regulator board. The regulator sets up RFI. If the LED bulbs are just an array without components, all should be good.
I forgot about LED's good point .
LED lights have been known to interfere with tv signals.
Im not sure why ?
IM not trying to get off the topic, just trying to help the OP to resolve his issue.
Does it have something to do with the electrical wire and the tv cable interfering with each other ? Being run too close to each other or maybe touching each other somewhere in the rv ?
IF so, to see if that's the case , would it be a good idea to temporarily try to run a tv cable directly from the roof antenna to the tv where its isolated from those electrical wires ? Just to see if it resolves the issue ?
ok, thank you, much appreciated .
