blt2ski
Jun 09, 2015Moderator
IIRC the aisin trans has a 3.54 first, od is .74 ad dod is .64. The 68rfe is similar to the ally 1000 and Torqueflight with .71 and .61 od/dod and a 3.1 first gear.
If you do free way miles, the 68 rfe is fine. If you go off road, need a bit more startup, you have the equal to a .4-1 lower axel ratio! or around .7-1 if you include the TC multiplier.
More than enough reason for me to go with an Aisin. This is more like the Ally 2400 or 3400 trans gear setups. Many times with higher gcwr and gvwr ratings too.
Marty
Marty
