bkenobi
Oct 18, 2017Explorer
The slit in the back window would work just fine if you could make sure the center rear view mirror was exactly in line. If that's the case, it will create a vertical reference plane. If you had a point on the leading edge of the cab over, that would also be a low tech version of the laser method. I like that approach cause it can't run out of batteries.
44,066 PostsLatest Activity: Oct 04, 2013
