bkenobi
Oct 18, 2017Explorer
The red laser works ok in the center, but the periphery is a lot dimmer. The issue with that is, dim red laser light can't outdo the break lights. I may look around to see if I can find a green laser to see if it's visible with break lights.
I mocked up the setup with the laser level and 3 tape strips. I had no issue lining up the center and with a slight correction believe I had it nailed. I didn't pull the tailgate to trial load. It's WAY too windy today to want to mess with raising the TC today. I'll probably try using it next time I load and have the boss make sure I don't mash anything.
44,066 PostsLatest Activity: Oct 04, 2013
