okan-star
Oct 20, 2017Explorer
I have happijack pad - bumpers at the front , mounted on steel angle on my flat bed and short pieces of angle in the rear that the camper drops in between , its in exactly the same place in the bed every time , I don't have to re-adjust the fast guns
Try this : after backing about less than a foot to the front of the box ,to about where you would to hook up the power cord , assuming you have the connection in the front of the bed , if you notice the front of the camper needs to go to one side , crank the truck wheels all the way that way and back up , that will pivot the camper in the bed at the front only ,to get the front where you want , if the back is now not centered , amusing your jack controller reaches , push on - lean on that jack until the camper starts to contact the bed when you bring it down
Repeat a few hundred times
Now that they make a truck that backs a boat down a ramp by itself , how long until it drives under a camper , I`d rather do it myself
44,066 PostsLatest Activity: Oct 04, 2013
