- TerryallanExplorer II
Rookiecamper wrote:
Wait!! I'm a little confused. I now have a different set-up, but when I had my anti-sway bar, if it was extended too far I think it would have come apart. Actually, I think it would have ended up bending around the ball before it had the chance to pull too far and slide apart. Maybe I'm thinking wrong so please feel free to correct me (I know several of you won't miss the chance!). Either way, I'm just not sure it would have done that on my previous set-up.
I'm kind of where you are. I can't really visualize bending it buy pulling it out. Like you. Mine would just come apart. UNLESS, the tongue was against the swaybar, and like a fulcrum pulled or levered it forward. - MvanderExplorerYou might want to measure where the new one goes in relation to the little ball on the shank. It's possible that it was incorrectly installed the first time. (to close or far)
- RookiecamperExplorerWait!! I'm a little confused. I now have a different set-up, but when I had my anti-sway bar, if it was extended too far I think it would have come apart. Actually, I think it would have ended up bending around the ball before it had the chance to pull too far and slide apart. Maybe I'm thinking wrong so please feel free to correct me (I know several of you won't miss the chance!). Either way, I'm just not sure it would have done that on my previous set-up.
- segen77ExplorerYeah, we always take the bar off backing up. I'm guessing we just turned too sharp at some point.
- jfkmkExplorer IIAlso, take the sway control bar off when backing into your site.
- DutchmenSportExplorerYea, don't mess around fixing the old one, just toss it and get a new one. Sometime in the past, you turned too sharp.
- segen77ExplorerThanks. Found one online for about $20.
- bgumExplorerSway control ball mount trailer end from PPL in Houston.
- segen77ExplorerIt was mounted on the passenger side of the trailer and was pulled forward, so I guess it means I turned too sharp to the left, and was almost pulled off?
As this something that can be purchased online? If so, what is the part called so I can search for it?
Thanks again - bgumExplorerGo buy a new one at a local trailer shop. It means you have turned to sharp and nearly pulled or pushed the ball off. The way mine is mounted it would have been a sharp left turn.
44,056 PostsLatest Activity: Mar 02, 2026
