kohldad
Apr 29, 2020Explorer III
The odds of having to remove a fridge from a unit over it's life is extremely small so the sacrifice of having to remove the door to change it out is an acceptable risk. General the same size danfoss compressor fridge will fit through a door so getting the upgraded unit in is a piece of cake. The old unit can be removed without removing the door by removing the cooling unit from the back. If the unit was operational, it can be reinstalled fairly easy with the only additional item of some heat transfer paste.
44,068 PostsLatest Activity: Jun 17, 2026
