cannesdo
Oct 14, 2014Explorer
Issues with my 2001 F-250 7.3L transmission continue...
Ooookay...Here's the deal. I bought it in '07, have been using it to tow my 15K fifth-wheel since then. I move maybe 2-3 times a year then I stay put. Previous owner was a rancher in TX and there was a gooseneck hitch in the bed I couldn't get out (welded) so I'm sure he was hauling heavy loads as well. Five days after I got to Woodland Park CO this summer (I've always taken care to pull over on steep long inclines and had an Edge Chip plugged in off and on -- I know, I need to upgrade) it started failing to shift up. First it seemed like the higher gears, then later almost exclusively btwn 1st and 2nd. It would just rev higher until you pulled your foot back and then it would usually shift. Worse in Warm weather, often nothing in cooler weather.
I took it to a trusted guy up there and he couldn't get it to do it. Thought I'd wait and see how it does down in Phoenix and it's just as bad here, but -- plot twist -- it developed something new just as I arrived in town on the trip here. It's a popping, clunk of a sound -- sounds like a cookie tray being flexed. They thought it was ball joints but fized those (they were due) and the noise was still there. I got it over to a guy I really like and trust who is really affordable ("A" rating with BBB and no complaints in 3 years...4.5 out of five stars on the ratings and all the guys in the shops around him say he's oozing integrity and works on all their cars) and he thought it might be the fly wheel but got in there and spun it and can't see any cracks. He says there might be hairline fractures in the transmission housing that could make the shifting thing worse in warm weather...
The popping sound is a lot worse when the trailer is hooked up. I had to crawl the last 6 miles to the park so slowly it took be almost an hour to get there. It doesn't do it in reverse for some reason -- hooked up or not. It's worse when you accelerate and I have to keep the pressure absolutely even or it would lapse into these popping convulsions that only a few times actually made the whole truck jerk a little. It sounds like it's coming from right down at my feet, towards the center. He says he's 80% sure it's all transmission issues and says there's a slight chance there's some injector issues but really doesn't think that's the case. Seems that with both the shifting and the popping -- and the history -- this transmission is really not...healthy..
So now I have to decide if I want hime to take it apart, examine everything, try to upgrade everything we can, replace the housing and hope that when we put it back together everything is resolved, or just put another transmission in. I know Allison transmissions are the gold-standard and would eventually like to go that route but the recession destroyed me and I'm just now getting comfortable again and looking to pay off my rig and really don't want to go there quite yet. So I'm looking at getting a used transmission. Seems to me anything I get will be in far better shape than one that's been doing heavy towing for 13 years. I'm also on a mission to lighten my load by at least 1000 lbs.
He says that's what he would do. Any thoughts? The guy who drove it in Colorado said the transmission felt really good to him (it wasn't doing the revving thing that day and had not yet started the popping). The popping thing just sounds so awful that you cringe the whole time you're driving it. The first garage I had it at the guy took it for a drive and didn't get out of the parking lot. Declared it unsafe to drive.
It's almost a crumpling sound. But he's ruled out the suspension because he can really beat it up on bumpy roads and it doesn't sound any worse.
I'd appreciate any input/advice. I'm female, former owner of 3 Subarus so this is new territory. Also wondering if it's anything I did that could have caused the present problems. Met a guy at the pool the other day from Canada who drives semis and says it isn't. Says 15K lbs isn't too much weight a truck like mine. Does it seem par for the course that a ttransmission that's been hauling for 13 years might just finally******out? How long would you expect one doing heavy work to last? And how can I best take care of the next one? And what's the best chip system for an upgrade? Max transmission temp? I didn't like driving here withoutt the gauges and didn't know there were big climbs between Peyson and Phoenix. I swear that last big one is what did it in.
I'm just not comfortable with taking it apart and putting it together again only to find out it's still messed up. And at least the new "old" tranny will have a 1 year warranty.
He's estimating $1500 to $1600 for the new (old) tranny/labor out the door....
