Cummins12V98
Mar 31, 2020Explorer III
ACZL wrote:
Lots of good advice and based on what you intend to do and perhaps not mentioned but may do so down the road, opt for a 1 ton SRW w/ the diesel. More than enough power and able to tow up to 15k safely should you decide to get a larger RV. Again, based on your needs, don't think you need anything larger than a DRW IF you ever went w/ a very large coach. Should you want to do that, THEN consider a 4500 and up. Think you'll be very happy w/ the type of truck your looking for.
Well I sure see ZERO reason to go to a 4500. I think I tow heavier than anyone on here and my DRW handles the load GREAT. I tow WestCoast and have been in some insane winds and the truck is imply planted to the ground.
44,066 PostsLatest Activity: Apr 16, 2026
