I have a 2008 Arctic Fox 990. I started to raise it ion the truck today and the right rear jack did not run. checked the motor and it ran fine. Checked the power and there was no power to the plug usi...
The controller should be under sink. There is a fuse for each jack - I think one of the upper ones is wired to the right rear (mine are labeled). Use the tether to verify you do not have a bad battery causing weak signal and use the red backup remote to verify it is not primary remote issue.
