Vinsil
Apr 07, 2016Explorer
Three wedges in mine, I can rotate them in and out without jacking up the truck. I prefer it this way so if I had to take a shim out on the pack I would. IIRC, you adjust the pack with shims on the bolts to adjust unless you need a ton of adjustment which I believe torklift said to take a wedge out. I like that I can engage and disengage them with only a rachet and extension. YMMV...
44,026 PostsLatest Activity: Feb 24, 2025
