ssthrd
May 07, 2020Explorer
Mike134 wrote:naturist wrote:
I've had a couple flats on a tandem axle trailer. Fastest/easiest/safest way to do it is put leveling blocks down, run the good tire up on the blocks high enough to raise the blown tire off the ground.
Don't forget to remove the WDH bars before driving up. They shift weight to both trailer axles and front truck axle
Never thought about that. Sounds like good advice. Next flat on the road (Wait--what?) I will disconnect the bars.
For now, I am only doing maintenance--repack bearings and have a look at/adjust brakes, so I will be hooked up but no WDH.
