thoms's avatar
thoms
jacking up tt
first off thanks for all the info on buying tires. got 4 carlisels coming.
What is the best way to change all 4? Jack up one side at a time using jacks and jack stands or doing both front first and then the rears??
Or any other ideas?
thanks again!!!
  • crazyro wrote:
    What is the best spot you recommend jacking up trailer? Axle close to wheel? Frame? (sorry for the thread hijack)
    Never jack using the axle on a trailer. The tubing is thin unlike the cast ones on a car or truck.
    I use a bottle jack with a piece of 2x4 on top under the frame next to a spring shackle for one tire. If both tires I do the same as for one then place a jack stands and move the bottle jack next to the other spring shackle.
    I never place the jack under the pivoting link for the springs between the tires.
  • be careful you don't twist the frame. do one side then the other
  • I made apt with Discount Tires for 30 min before they opened and had me back the TT near the work area and had 4 workers come in early and had me out with all 4 tires mounted, balanced etc before 8AM
  • What is the best spot you recommend jacking up trailer? Axle close to wheel? Frame? (sorry for the thread hijack)
  • LadyRVer wrote:
    Recently I had 4 new tires put on my trailer The tire shop lifted one side, changed out the two tires, let it down, then lifted the other side and did the other 2. Seemed logical to me.
    This...
  • Recently I had 4 new tires put on my trailer The tire shop lifted one side, changed out the two tires, let it down, then lifted the other side and did the other 2. Seemed logical to me.
