Jerry9n
May 26, 2013Explorer
When I got my flat screen to replace the CRT I over thought the mounting while traveling. It sits on a low cabinet. The TV has a non slip base, so I put some 3M locking strips on the top to the wall. I put a zip lock with bubble wrap between the back of the tv and the wall and latch in the two tabs. Hasn't moved an inch while traveling. Just unlock the two tabs and you can move the tv wherever you want.
(I originally used a foam block between the wall and tv--too messy).
