trail-explorer
Oct 27, 2015Explorer
rjxj wrote:
You are probably looking at it on the bottom of the tank. Water and the agitation of travel work well. Not traveling and a small amount of water are bad. If parked a lot dump 5 gallons of water in. When you are ready to dump put in even more water.
Yep, that's most likely the bottom of the tank.
It's normal for a pile of poop to build up if there's not much water in the tank.
THe solution to get rid of it is dump a 5 gallon buck of water in to the toilet to wash away that cra-p-p-y mess.
It might take several buckets full of water at tank dump time to clear out the pile-o-poo.
44,056 PostsLatest Activity: May 04, 2014
