You will want to look closely at the hitch weight of that 233RBS. A 635 lb dry hitch could easily be an 800-900 lb hitch when you're ready to camp. Have the dealer stack the LP and battery on the tongue, and weigh it. Then think about where the water tanks are; is the 49 gallon fresh tank near the front? Then think about what you'd stow where in that trailer, and how much heavy stuff you might have near the front (don't forget that exterior storage compartment). And since this is a 25' TT, will you use a WD hitch with sway control? Add the weight of that device, it's part of your hitch weight.
