valhalla360
Aug 11, 2020Navigator
The payload is likely the killer.
I did a quick check online and it looks like you only have 1100lb payload. At 6200lb, you should have around 700-900lb hitch weight. Assuming 2 of you at 150lb plus 100lb for the hitch, that puts you at 1100-1300lb before putting anything else in the truck and that presumes you don't have any after market add-ons (like running boards).
290hp should actually be fine. You may need to drop down a gear and let the RPM go up to make that 290hp but if you look at tow vehicles from the 1970-1980's, it was common for big V8 engines to have 200-250hp.
Ignore the unloaded weight and go for the GVWR of the trailer for a good starting point. Given the payload limits, I'd be looking at 4500-5000 GVWR as the upper end of trailers to consider.
