I have a 338rets 40 ft Jayco bumper pull TT. Just installed JT strongarms. Is it nessarary to install the 2 rear arms. I'm wondering if the hassle of welding angle iron to accommodate the brackets be...
I think the rear struts would give you additional noticible stability by anchoring the rear of the frame to the foot pads.
I did not want to weld to the frame. I cut a piece of 2"x2" square tube the width of the frame. I cut each end at 45 degrees and drilled two 9/16" holes in each end. Then mounted that tube to the frame using 1/2" self tapping bolts. Attached the JT mount go the center of the tube. Provides a very strong mount.
