Before you muck around with a new rear-end, what gear are you running going up hills.
- If you are regularly in 1st gear struggling to do 20mph, the deeper rear-end might help boost the speed a bit.
- If you are typically running 3rd gear or higher, you likely won't see much improvement. It might hold a higher gear but engine RPM won't be much different for the same speed because while the higher transmission gear will lower RPM, the deeper rear-end will raise the RPM back up.
HP is what determines speed up a steep grade. HP = Torque * RPM. Gas engines are generally not designed to put out massive torque, so increasing RPM is how you generate lots of HP. Modern gas engines are quite happy running 3500, even 4000 RPM. It's just beyond what most people are used to so it feels uncomfortable.
Yes, in theory you could add a turbo but that comes with a whole set of complications that would be cheaper and more reliable to solve by buying a turbo diesel truck.
