westend
May 01, 2015Explorer
thcguy12 wrote:The kit comes with 40' of wire. If you cut the wire in the middle, you will have two lengths of 20' with the MC4 plugs on the ends. The plugs are snapped into the panel's MC4 connectors and the two wire ends connect to the solar charge controller.
That windy nation kit doesn't come with any way to connect to battery. That means going out and buying extra items that hopefully connect to that one. Plus screwing into my camper which I prefer not to do.
What's not in the kit is two short cables to connect the solar charge controller to the battery. You can purchase that at an auto parts store. In fact some real knowledgable guys that use solar have made good use out of jumper cables. You could cut one end off a set of jumper cables and attach the jumper cables to your battery.
If you leave the panel and the other bits as a portable set, you won't have to master a screw driver or use any tools besides a wire stripper. This is very easy stuff.
