Lifemember
May 26, 2015Explorer
I own a 1996 Prism that I have gutted and remodeled the inside. If you are leaking into the storage area it will be coming from the front window or the molding strip on side of trailer. also check the seam above front window in location of the rubber roof that joins the front fiberglass. You might also need to pull the front window and reseal. Check to see if any delamination is going on.
