thcguy12's avatar
thcguy12
Just bought first camper - lot of questions - can you help?
First off hello - we just bought a 1996 Thor Prism 2000 from a good friend - got a screaming deal on it for only $1500 (nada guide says about 4000 min). So we are very happy. I spent weeks scared and stressed about towing for my first time - drove it home last night and it was so easy. This week we are getting it ready, cleaned, decorated, and tuned up before we take it up to our mountain land where it will stay for the rest of it's life (unless we get a bug to go somewhere). We have 40 acres so it's not often we camp anywhere else.
I have some questions though - and am hoping you all can help:
1.) We discovered last night it came with a full HOLDING TANK. I think that is the poo tank right? Where can we go get that emptied and flushed out?
(we will not be using the restroom or any running water up at land - no hookups there).
2.) There are a few window seals that seem to have a tiny leak into the storage compartments below them. What do you suggest for sealing them - maybe some clear caulking?
3.) Now it did not come with any manuals so I need your help here. The previous owner says you simply hop on board - click the fridge to gas and the heater button on and everything starts working. I asked if you have to light a pilot outside and he said no. That doesn't seem right to me but maybe you all can lend some experience?
4.) What can a deep cell battery run on board? First I should let you know we plan to use same battery all summer without charging - then bring back and trickle charge all fall/winter? I know the basic lights for at night. What about a small stereo once every couple weekends (it came with a cassette player - ha ha)? What about some awning lights? Cell phone charger? A tv for playing dvd's? Disco dance ball? We will never have a way of plugging it in up there - wondering what we can get away with. Don't want to drain the battery in one night with friends.
5.) Will plugging the camper into your car and running your car charge the battery if it ran out?
  • The battery runs the control board on the refer, water pump, lights, CO2 detector, furnace fan and control board, power supply for television antenna booster, and any built in entertainment (radio / CD player etc) system. It won't last all summer.
    Charging with car and jumper cables, is not very effective and very costly. You're going to need some other type of charging. A generator and / or solar panels and multiple batteries, would be more in line with a seasonal use.
    If the trailer is sitting unused and the battery is left connected, even with everything turned off, parasitic draws from the control boards, radio, and CO2 detector, will drain the battery in 7 - 10 days.
    Using the furnace on a single battery without charging, you can estimate your run time in hours, not days.
  • thcguy12 wrote:
    He has been using the same battery for five years now doing that.
    And what is the voltage reading at the end of months of use?
  • IN REGARDS TO THE BATTERY:
    The camper we have up there now (my wifes fathers camper) uses one deep cell battery all year. We go up about once or twice a month and use it just for lights at night. It does fine from April 1st to about Sepetember when we take it home and fall chill arrives. Never had an issue. He has been using the same battery for five years now doing that.
  • 1) There are two holding tanks, black (poo) and grey (sink/shower). How do you know it's full? The indicator lights? They are often faulty due to residue on the sensor. If it really is full, go to http://www.rvdumps.com/ to find a dump site near you. Google how to dump properly. Hopefully it hasn't been sitting for years or it might be hard and extremely difficult to get out. Always keep some water in the tank after dumping (several gallons) to keep things soft.
    3) Some water heaters/furnaces have pilot lights, many have electronic ignition. Fridge doesn't. Just flip the switches and go. Remember to keep the trailer level, or the fridge will not cool properly (short term) and fail (long term).
    4) Battery will run all the 12V systems. Lights, power jack (if you have one), slide. Anything that runs on 120V won't work. TV, A/C, cell phone charger etc.
    5) I hear that it depends on the vehicle. I have no experience with this (never tested it out)
  • OP quote:
    That is not going to happen. With a single 12 volt battery you would be lucky to get 2-3 days of regulated use.
    A battery should never get below 50% & remain there for very long, or you will murder it.
    Get a small generator or install solar
    I suggest you do some extensive reading on this Forum.
    Is that a joke?
