jaycocreek
Sep 13, 2020Explorer II
You can buy any size/width of ratchet straps you want..I have a pair of 30K ratchet straps..Four inches wide,same width as semi straps..
They come in different sizes Kayteg..LOL..NOTE..The 1/2/3/4 is the width of the straps in inches or "...Not number 1-2 etc..
I can't tell you how many miles I put on this truck without any tie downs as known on the internet..Just a chain from the front stake pocket to the rear TC tie down and a swimming noodle to keep it from rubbing the paint..LOL
Look Mom..No tie downs!
All kidding aside..When I first started truck camping,there was no Torklift or HappiJack tie downs..We had to just make it work and we did it with whatever..Straps will certainly get you home and if your creative,without any scratches as we did for years before these expensive setups.
1” Ratchet Straps have a breaking strength that ranges from 3,000 - 6,000 lbs depending on the webbing and hardware.
2” Ratchet Straps have a breaking strength that ranges between 6,000 - 12,000 lbs, and WLL ranging from 833 to 3,333 pounds depending on the hardware ends.
3” Ratchet Straps have a breaking strength of around 15,000 lbs and WLL of 5,400 lbs or less depending on the hardware attachments.
4” Ratchet Straps have a breaking strength of around 15,000 lbs lbs and WLL of 5,400 lbs depending of the hardware.
44,068 PostsLatest Activity: Apr 17, 2021
