- Golden_HVACExplorerHi,
I always run my refrigerator on propane while driving. It is a small risk to run the propane while driving, yet so is filling the gas tank and driving anyplace. It is a small risk, and the propane leak detector will shut off the propane if something happens.
Good luck, and enjoy the new (to you) trailer!
Fred. - Community AlumniWe just run our's on propane like most who travel high mileage trips.
- Old-BiscuitExplorer IIISome folks are scared to operate fridge on propane while in transit.
RV fridges can be operated on propane while in transit........mfg. have designed them to operate while traveling and they have features that shut them down safely IF issues arise
The fridges when OFF can hold temps for several hours......IF completely cooled down and as long as door if left closed.
BUT way chance spoilage/bacteria growth when fridge can be turned ON :S
Run it on propane and enjoy safe, cold food
Just think about this:
If unsafe to operate while traveling.......do you want to operate it while sleeping :H - Bird_FreakExplorer III was about to ask if the fridge did not work on gas.
- donn0128Explorer IITurn on the propane, bleed the air out by lighting a stove top burner. Turn the refer on, either auto or gas and go. The majority of us travel with the refer on. The rest? Guess their too paranoid to do it.
- dadmomhExplorerThere are a couple of small buttons on the top of the frig, assuming it's new or relatively new, and if you turn it to on and then set it to "Auto", it will switch over to propane when you unplug from shore power. It will take a few seconds/minutes to change. As soon as you get to the campground and plug back in, it'll go back to electric. Hope that helps. While you're on the road you can keep the propane going by just leaving it at "Auto" and it'll stay cold the whole time. BTW, it will take several hours for it to cool the first time, so don't worry if it doesn't seem like a home frig. Congrats on the TT.
44,056 PostsLatest Activity: May 04, 2014
