- LarryJMExplorer II
NanciL wrote:
We won't run our refrig. on gas while traveling.
I don't care what others say.
My manual advises not to and I'll go with that
Jack L
Well that statement ran my B.S. Flag FULL STAFF. What make and model of refer and what is the manual nr. on the document you are referring to. Also, the page nr. would help, but I won't be holding my breath since I seriously doubt that recommendation is in any refer manual.
Larry - mosseaterExplorer IIAs stated, bleed the air by lighting the stove first to make sure you have gas to the closest point to the frig. Make sure it lights, don't just hit the button and walk away. If you do and it doesn't light, the control will lock out on flame failure and you'll have to reset it, usually by turning the "propane" button off and then back on. It's a very quiet burner, but you can usually hear it running if you listen carefully. I believe the indicator on the frig button lights also when it isn't operating, or maybe it blinks. I always check mine after I unplug for a trip but before we pull out.
Also, remember to shut if off if your trailer is parked off level drastically for a longer period of time. - PAAKExplorerI run with the propane on at times. But unless your destination is only an hour away, it will still be good in the fridge if it is off. Things wont spoil that quickly. There is nothing wrong with running propane while you are on the road.
- B_O__PlentyExplorer IIBeen running mine on gas going down the road since I got my first trailer with a gas/elec fridge and electronic ignitor back in 1993..Never had a problem ever. I travel about 7,000 miles and spend about 100 nights a year in my rig, so it's not like we don't use it. I'm not making any plans to drink warm beer and eat spoiled food at the end of my trip..
B.O. - bobjogoneExplorerWe turn propane off while traveling. We us keep two ice packs in freezer for day use and they help keep it cold. When we're traveling more than 4 hours - we add frozen water bottles the day before for fridge and freezer.
- NanciLExplorer IIWe won't run our refrig. on gas while traveling.
With that said. the day before traveling we turn on the refrigerator and leave it on overnight.
My wife loads all the frozen stuff from our home freezer in and yes it stays solid for an eight hour trip, and the milk etc stays nice and cold.
We have been doing it this way for many years, and will be doing it again shortly when we head to our snowbird destination.
Jack L - Crazy_RayExplorerGary can you give a LINK for the states about turning propane off when filling up???
- Dennis_M_MExplorerWe always run with the fridge on propane.
- Old-BiscuitExplorer III
mhardin wrote:
Golden_HVAC wrote:
Hi,
It is a small risk, and the propane leak detector will shut off the propane if something happens.
Fred.
Huh? The propane leak detector will shut down the propane? Mine doesn't have any connection to the propane supply. Maybe you mean the safety valves that sense a high flow and shut down?
BTW, I always travel with the propane on and the fridge running.
SOME rigs have emergency shut-off solenoids activated by LP Leak Detector. If it is not ON/Good solenoid won't open. If it alarms solenoid closes.
SOME rigs........ mostly MHs------not many any more
BUT fridges have built in features......flame proofing. No main flame.no propane flow - mhardinExplorer
Golden_HVAC wrote:
Hi,
Fred.
44,056 PostsLatest Activity: Feb 28, 2026
