the tires are 16" apart (at the closest point) and the roof is a full walk on roof.
There is also a black tank flush hook up right in front of the back door, this wasn't advertised in anything that i saw, the dealer called the factory to make sure that's what it was, mine isn't labeled or anything.
I just messed around with the awning, it has the gas shocks so if the water on top gets heavy enough it will dump either side, and you can also manually dip one end and tighten it so it stays that way.
Reminder...this is my first one to own and i'm just thinking of other questions i had about stuff that i wasn't too sure about, so if it sounds like i'm posting worthless info...it wasn't worthless to me a couple days ago!!
I'm going to try to figure out how to post pictures...
