cottonrvers wrote:
as for removing the tvs from their brkt you first have turn the panel around to the rear remove four screws and the panel, Once the panel is off there are two philip head screws you can access from the opening. Remove the two screws then turn the tv around and it will lift straight up. I installed one set of a/v cables to the upper opening then one in and one out a/v cable to the bottom. I picked up a set of a/v inline adapters from radio shack which allows you to plug other a/v cables in without removing all that stuff each time. Worked really well.
Thanks!!!
I was wondering that as well, I tried pulling up, pulling bottom out first and everything else....besides taking the back off.
