I'm at a campground now and just figured out there is no heat coming out of the bunkroom heat vent, the others have very little air coming out. I looked through the louvers to the furnace and I can see an open hole on the side, I figure either a plug fell out/wasn't installed or the rear duct came out of that hole. Of course that panel is held on with the square bit screws so I'm about to get a set of those.
I wonder how acurate the tank levels are? I'm at an elec only site, I filled the fresh water tank (40 gal) this morning after my wife took a shower, not a long one, not much other water useage, the levels read fresh 2/3, gray full, black 1/3.... The numbers don't add up. If the gray. Tank gets too full where will it go? Back up into the tub?
I need a tote!
