I agree that when we first walked into the Premier, the lighting inside seemed to be more subdued, "warmer" than with our old Tango. I think that the light fixtures put out a much more yellow light than the white light we were used to and I was worried about the lights not being bright enough at night.
Having lived with it now and using it in late October/November, I found that it's not a problem at all, but we do have to turn on each of the lights for all the areas instead of just one light for the whole room.
prov431 wrote:
Hey btw, I notice your signature picture...does your TT really sit that high in the front when towing or is it jacked up? You may need a drop hitch if it's towing that nose high. I wonder if this is partly due to the smaller 14" tires?
I've got a ProPride hitch so unfortunately I can't just go out and buy lower drop hitch. I haven't contacted them yet to ask if there was any way to adjust it lower than the lowest setting where it's at right now. In the picture, it's more nose-high than it currently is, but it's still nose-high. It took me a little while to get the setup tuned correctly, but it towed great for our entire 5000 mile trip. I think if the tires were bigger it would probably even it out a bit more.
