VirtualGarage wrote:
There is a risk of freezing starting in October so I bought an air compressor so that I could winterize the RV more easily than using anti-freeze every weekend we went out.
Thanks for your report, it's still months before we can take ours out. We will camp a few times in early spring when there will be possible freezing temps. I've also thought that between our few trips to use the air compressor technique. Did you use instructions from a certain site that helped explain just what to do?
Come on spring!
EDIT: Which air compressor did you use?
