garysol wrote:
VirtualGarage wrote:
The back room doesn't get as warm as the front bedroom and I've thought about getting a space heater but I was worried about how much of a power draw the trailer wiring can support.
What are your thoughts on partially blocking off one of the front vents to help force more heat out of the rear vent?
The duct that goes to my rear bunk area vent was disconnected at the furnace, figured it out while camping one night, wondered why it wasn't getting as warm in the back. I could see it through the louvers under the oven? Or fridge? Can't remember which one it is under. I had to go get a set of the square bits for those screws to take the panel off to fix it.
May want to check that out to make sure your ducts are all attached good.
