joesofa wrote:
Mine quit at the campground. It was not grounded well enough so I put a short ground wire on it and it has worked fine.
Could you explain exactly how/where you did that?
I discovered this weekend that our power jack was having the same problem as it did before. The dealer had diagnosed it as a loose ground and I suspect it is the same problem. However, I took a look at the jack and could only see the red power wire. I couldn't figure out where the ground was to check it :h.
I'm heading back next weekend and I don't want to make a special trip to the dealer to have it looked at again.
When I installed a Barker on my Tango, the ground was simply one of the three bolts that held the jack to the frame. I couldn't really tell on the Premier. Where did you attach the ground wire to?
Thanks!
