msalyer wrote:
Mods so far on my 28RL Premier:
...Moved 19" included flat panel TV to bedroom on wall mount. Installed new 32" flat panel in living room.
...Mounted three power strips to make up for inadequate number of recepticles. One on right side of bedroom (left side had recepticle). One under kitchen window above counter. One next to etertainment center.
....Removed blank panel under oven and replaced with matching cupboard door ordered by dealer from Keystone. Looks factory and should be (are you listening Keystone?). NICE extra cupboard just right for pots and pans.
Keep us informed on what else you do. We have the same model. Nice to hear you put the door in under the oven area. Can you think of any reason for them to not have done this? Just a money saving thing, heat from oven, were there any propane lines or other lines in the way? How much space to you get?
Did you have to do any modifications for the 32" tv on the mounting because of more weight or just how you connect to the wall mount?
How did you connect your power strip to the right side of the bed? When I discovered this issue last year (we only had it a week before we had to store it!) I just ran a cord from the left side to the right. Would like something more permanent. I'll have to check on the kitchen area and what would work for me there also.
Thanks for your comments.
It's SNOWING here today! 5 days to get camper out of winter storage! yeaaaaaaaaa :)
garysol I feel your pain!
