NetAndDavid wrote:
I went to Home Depot and picked up a sheet of plexiglass for $16.00, and 12 velcro squares for $4.00. I have to go to the storage lot this week to measure the outer diamater of the box so I can cut it, (or if someone has thier unit at home) I am going to cut it so that it matched the yellow outline in virtual's post and attach the velcro to the corners. Once I get it done I'll post some pics. Thanks again fot the idea!!!
That's awesome. One thing about putting velcro only on the corners is that there will be a gap along the sides and bugs could potentially get in that way. If you put the velcro in strips all around the edge, it would be overkill in terms of holding strength but it provide a tight barrier. You should be able to buy hook & loop (velcro) fasteners by the roll.
