garysol wrote:
NetAndDavid wrote:
I went to Home Depot and picked up a sheet of plexiglass for $16.00, and 12 velcro squares for $4.00.
So how are we going to mount the velcro strips to the wood frame so that the strips do not pull off every time we take the Plexiglas off in order to spin the TV around??
What if you mounted the plexiglass on hinges on one side so that it opened like a cupboard door instead of using velcro? Then you could use felt/rubber strip to seal around the edges. Might be better than two sided velcro strips.??
