SabreCanuck wrote:
I was talking about the existing Coleman Stove that swings out from under the sink.. The supply line to that stove is supposed to be fed through a little hole in the fairing and plugged into te supply line under the trailer.
I'm just thinking of drilling access hole through "outdoor kitchen floor" and running the hose through it and never unplugging it.
My question is whether or not the quick-connect fitting would provide as good a weather-proof connection as the traditional propane Acme nut does. If not, it could probably be protected if needed. Being located near the wheel area, would the exposed hose get any additional wear and tear from the elements?
The other issue is drilling a hole straight up from underneath the RV to under the sink counter. I'm sure you could seal it so that no moisture enters that way, but I generally don't like to drill holes. There may be more material to drill through there than anticipated.
