garysol wrote:
VirtualGarage wrote:
I don't see why not. It would be just a matter of finding the fitting/adapter: One end of the hose would be the quick-connect fitting that goes to the RV and the other end would look like the end of a traditional propane tank.
Problem there would be that you would be flowing the propane through the regulator on the trailer and then again through the regulator on the grill. We would need to find a way to bypass the regulator on the grill.......... I think.
I'm beginning to think the outdoor grille setup on the 27RBPR is different than the 31BHPR??? My 'coleman stove" swings out from under the sink and has a 3' hose on it. The hose is attached to the stove, but is hanging free at the other end. When the stove is swung out, you feed the hose through a hole drilled in the side panel and it plugs into the camper with a 'hydraulic' looking connector under the camper. This is by Keystone design.
MY design is to leave that factory plug plugged in all the time and route the hose through the floor....
But, I have go give it more thought before cutting hole through floor.
