AMPS! For our model Bullet Premier 28RLPR we have 30 amp and use the Progressive Industries protection. When all things are turned off it shows 3 amps of current usage on the Integrated Information Panel, so what are these 3 amps? I was surprised to read that the converter can take up to 5 of your amps just to operate and keep things running in your TT. This means the most you can try to use at full usage is probably 25 amps? The converter charging the battery is probably part of these 3 amps I see. I also understand the indicator lights for gas detector, microwave lights, entertainment system lights (which I'm not sure are readily turned off) can be as much as 1 amp. This sort of surprised me. Maybe I'm late on trying to figure this all out.
So I guess it's really only 25 amps if I dare to use it all at the same time, but with summer coming and air conditioner use I wanted to try to understand this more and not blow breakers left and right! I'm not going to overkill this topic but want to learn what appliances use how much amps in my specific Bullet TT and be prepared. Guess I'll start a list of the appliances I use and test for how many amps they use. Happy Camping!
