garysol wrote:
65ShelbyCobra wrote:
I know it doesn't pertain to the models you are interested in but I thought I'd throw this out there to all 31BH owners. I've slowly discovered/detected over the last few months, a potentially huge problem.
I had the same issue. I adjusted the door by moving those little hinge inserts just a smidgen and it has never been an issue since. Ill keep my fingers crossed.
Which hinge inserts are you talking about? I don't remember seeing anything like that.
When I'm all set up, if I relieve enough pressure on the stabilizer below the kitchen to get rid of the binding on the door, another turn or two it'll be off of the ground.
